Elementary Boundary Conditions
- Option 0 specifies stagnation conditions for perfect gas (Bernoulli inlet).
- Option 1 specifies stagnation conditions for a linear compressible material (Bernoulli inlet).
- Option 2 imposes values (inlet/outlet).
- Option 3 is for non-reflective frontiers (outlet).
Non-Reflective Frontiers (NRF)
Option 3 of Material LAW11 is used to prevent outgoing wave reflections on the boundaries of the domain.
- An average pressure is imposed via a function. A relaxation term is added to let the average pressure converge toward the imposed value. This is well suited for outlets.
- An average pressure is calculated from the neighboring element pressure and the pressure converges toward this always changing value.
The impedance of the boundary is exactly the wave impedance of a monopole radiating at distance 2lc from the boundary, where lc is specified in the input data for this law.
This non-reflective frontiers (NRF) is not effective when velocities are imposed or when nodes are fixed.
