Venting and Fabric Porosity Activation
When there is no sensor to activate the gas injection, the vent holes and porosity become active when T > T s t a r t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGubGaey Opa4JaamivamaaBaaaleaacaWGZbGaamiDaiaadggacaWGYbGaamiD aaqabaaaaa@3E0C@ , or if the pressure P > Δ P d e f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbGaey Opa4JaeuiLdqKaamiuamaaBaaaleaacaWGKbGaamyzaiaadAgaaeqa aaaa@3D61@ value longer than the time given in Δ t P d e f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bGaamiuamaaBaaaleaacaWGKbGaamyzaiaadAgaaeqaaaaa@3C7D@ , where all these values are input using /MONVOL/FVMBAG1.
When at least one of the injectors is activated by the sensor, then activation of venting and porosity options is controlled by Ittf.
Tinj is the time of the first injector to be activated by the sensor.
Ittf = 0
  Venting, Porosity
Activation When P > Δ P d e f longer than the time Δ t P d e f , or T > T s t a r t
Deactivation Tstop
Time dependent functions No shift
Ittf = 3
  Venting, Porosity
Activation When T > T i n j and P > Δ P d e f longer than the time Δ t P d e f , or T > T i n j + T s t a r t
Deactivation T i n j + T s t o p
Time dependent functions Shifted by T i n j + T s t a r t
All other related curves are active when corresponding venting, porosity or communication option is active.
