An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
Hyperelastic materials are used to model materials that respond elastically under very large strains. These materials
normally show a nonlinear elastic, incompressible stress strain response which returns to its initial state when unloaded.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
Different material tests could result in different material mechanic character.
The typical material test for metal is tensile test. With this test strain-stress curve,
yield point, necking point and failure point of material could be observed. Figure 1. Force (F) and Length (l) are Measured
Engineer strain-stress curve could be generated by:(1)
(2)
Where,
Section area in the initial state
Initial length
In this Force-elongation curve or engineer stress-strain curve, three
points are important.
Yield point: where material begin to yield. Before yield you can assume
material is in elastic state (the Young's modulus E could be measured) and after yield, material
plastic strain which is non-reversible.
Some material in this test will first reach the upper yield point
(ReH) and then drop to the lower yield point
(ReL). In engineer stress-strain curve, lower yield
stress (conservative value) could be taken.
Some material can not easily find yield point. Take the stress of
0.1 or 0.2% plastic strain as yield stress.
Necking point: where the material reaches the maximal stress in engineer
stress-strain curve. After this point, the material begins to soften.
Failure point: where material failed.
Rm
Maximum resistance
Fmax
Maximum force
ReH
Upper yield level
ReL
Lower yield level
Ag
Uniform elongation
Agt
Total uniform elongation
At
Total failure strain
True stress-strain curve which is requested in most materials in
Radioss, except in LAW2, where
both engineer stress-strain and true stress-strain are possible to input material
data.
In Figure 3, find engineer stress-strain curve (blue) by
using:(3)
(4)
The result is true stress-strain curve (red). Plastic true
stress-strain curve is shown in green, which plastic strain begin from 0. This green
plastic true stress-strain curve is what you need, as in LAW36,
LAW60, LAW63, and so on. Figure 3.
The true stress-strain curve is valid until the necking point of the
material. After the necking point, the material curve has to be defined manually for
hardening. Using a different material law, Radioss will
extrapolation the true stress-strain curve to 100%.
Linear extrapolation: If stress-strain curve is as function input
(LAW36), then stress-strain curve is linearly
extrapolated with a slope defined by the last two points of the curve. It is
recommended that the list of abscissa value be increased to a value greater
than the previous abscissa value.
Johnson-Cook: After necking point, Johnson-Cook hardening is one of the most
commonly used to extrapolate the true stress-strain curve.(5)
However, it may overestimate strain hardening for
automotive steel, In this case, combination of swift-voce hardening is
more accurate.
Swift and Voce: After necking point, use one of the following equations to
Swift model
and are positive.
Voce model
, and are positive.
Combination of Swift and Voce model (LAW84 and LAW87)
Figure 4.
Here, α is weight of Swift hardening and Voce hardening. Here one
Compose script as example to fit the Swift hardening parameters , , and Voce hardening parameters , , with input stress-strain curve.
Hyperelastic Materials
Hyperelastic materials are used to model materials that respond elastically under very large strains. These materials normally show a nonlinear elastic, incompressible stress strain response which returns to its initial state when unloaded.
