/EREF
Block Format Keyword Describes the reference state for elements belonging to a part using given element and node identifier.
/EREF/SHELL/part_ID
eref_title
shell_ID node_ID1 node_ID2 node_ID3 node_ID4
/EREF/SH3N/part_ID
eref_title
triang_ID node_ID1 node_ID2 node_ID3
/EREF/BRICK/part_ID
eref_title
brick_ID node_ID1 node_ID2 node_ID3 node_ID4 node_ID5 node_ID6 node_ID7 node_ID8
/EREF/TETRA4/part_ID
eref_title
tetra4_ID node_ID1 node_ID2 node_ID3 node_ID4
part_ID Optional part identifier.
(Integer, maximum 10 digits)
eref_title Title.
shell_ID 4-nodes Shell identifier.
(Integer)
triang_ID 3-nodes Shell identifier.
(Integer)
brick_ID 8-nodes Brick or 4-node tetrahedron element identifier.
(Integer)
tetra4_ID 4-nodes tetrahedron element identifier.
(Integer)
nodei Node identifier I.
(Integer)
  1. Reference state will be applied to shell and solid elements only.
  2. Multiple /EREF entries are allowed in Radioss input.
  3. The element_ID is the same as in the initial state and node_ID coordinates defining the element in the reference state must be given in /NODE. The node IDs must be unique and are only used to define the reference geometry.
  4. The list does not need to contain all elements of a part, the initial state coordinates are taken for the missing elements.
  5. If an element does not belong to the specified part it will be ignored.
  6. Reference state is available:
