/ALE/MAT
Block Format Keyword Describes the ALE material.
/ALE/MAT/mat_ID
Flrd
mat_ID Material identifier
(Integer, maximum 10 digits)
Flrd Modification factor on boundary surfaces fluxes.
= 0 (Default)
Fluid transmission is not allowed.
= 1
Fluid transmission is totally allowed.
(Real)
#RADIOSS STARTER
#-  1. MATERIALS:
/UNIT/1
unit for mat
                   g                  mm                  ms
/MAT/LAW37/1/1
air (unit g_mm_ms)
#                Psh
                   0
#             RHO_l0                 C_l             ALPHA_l                NU_l            NU_VOL_l
                .001                2089                   0            1.787e-3                   0
#             RHO_G0               GAMMA                  P0                NU_g            NU_VOL_g
             1.22E-6                 1.4                  .1             1.48e-2
/ALE/MAT/1
#     Modif. factor.
                   0
/MAT/LAW37/2/1
water (unit g_mm_ms)
#                Psh
                   0
                .001                2089                   1            1.787e-3                   0
/ALE/MAT/2
#     Modif. factor.
                   0
#enddata
  1. If the boundary is not connected to a material specifying an Elementary Boundary Condition (TYPE11), the Flrd is by default 0. The flow is reduced otherwise by the Flrd factor value specified at the elementary boundary level.
    euler_mat_14
