/EULER/MAT
Block Format Keyword Describes the Euler material.
/EULER/MAT/mat_ID
Flrd
mat_ID Material identifier
(Integer, maximum 10 digits)
Flrd Modification factor for fluxes at boundaries.
= 0 (Default)
Convection is not allowed at domain boundaries.
= 1
Convection is totally allowed at domain boundaries.
(Real)
Example (Air)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                   m                   s
/MAT/HYDRO/4/1
AIR
#              RHO_I               RHO_0
                1.22                   0
#                Knu                Pmin
              1.5E-5                   0
/EOS/POLYNOMIAL/4/1
AIR
#                 C0                  C1                  C2                  C3
                   0                   0                   0                   0
#                 C4                  C5                  E0                Pmin               RHO_0
                 0.4                 0.4              253300                   0                1.22
/EULER/MAT/4
#     Modif. factor.
                   0
#enddata
/END
  1. If the boundary is not connected to a material specifying an Elementary Boundary Condition (TYPE11), the Flrd is by default 0. The flow is reduced otherwise by the Flrd factor value specified at the elementary boundary level.
    euler_mat_14
