HMIN_write_system_construction_data()
Writes construction axis and plane data for node-based system.
void HMIN_write_system_construction_data(HM_entityidtype id, double constructionaxis[3], double constructionplane[3])
HyperMesh hminlib Function
id
The ID of the system.
constructionaxis
The coordinates of the point that specifies the axis of the system.
constructionplane
The coordinates of the point that specifies the plane of the system.
None.
Version History
2019.1
