HMIN_system_writeatnode()
Creates a system at a node.
void HMIN_system_writeatnode(HM_entityidtype id, int type, HM_entityidtype systemid, double axis[3][3], HM_entityidtype nodeid, HM_entityidtype systemcollectorid);
HyperMesh hminlib Function
id
The ID of the system.
type
The type of the system.
  • 0 - For a Cartesian system.
  • 1 - For a cylindrical system.
  • 2 - For a spherical system.
systemid
The ID of the system in which the system is built.
axis[3][3]
The axes of the coordinate system.
nodeid
The ID of the node where it is defined.
systemcollectorid
The ID of the system collector.
This command is used after the HMIN_system_write command. For example:
HMIN_system_write(systemId, systemType, 0, axis, cordOfOrigin, systcolId);
if(nodeId)
   HMIN_system_writeatnode (systemId, systemType, systemId, axis, nodeId, systcolId);
None.
