HMIN_title_writeborder()
Writes the border of a title to HyperMesh.
void HMIN_title_writeborder(int borderon, int bordercolor, int borderwidth, double borderxmin, double borderxmax, double borderymin, double borderymax);
HyperMesh hminlib Function
borderon
Indicates whether the border is on or off.
  • 0 - If the border is off.
  • 1 - If the border is on.
bordercolor
The color to be assigned to the border.
borderwidth
The width to be assigned to the border.
  • 1 - For a thick border.
  • 3 - For a thin border.
borderxmin
The x value of the upper left plot window.
borderxmax
The x value of the lower right plot window.
borderymin
The y value of the upper left plot window.
borderymax
The y value of the lower right plot window.
The values allowed for the x and y coordinates used for border minimums and maximums range from (0,0) to (1,1).
None.
