HMIN_title_writeanchor()
Writes the anchor for a title to HyperMesh.
HMIN_title_writeanchor(int anchorpoint, double anchorangle, double distance, char * entitytypename, HM_entityidtype entityid);
HyperMesh hminlib Function
anchorpoint
Identifies the corner of the title that is used as the anchor point. Use the setting:
  • 0 - To use the lower left corner as the anchor point.
  • 1 - To use the upper left corner as the anchor point.
  • 2 - To use the upper right corner as the anchor point.
  • 3 - To use the lower right corner as the anchor point.
anchorangle
The angle relative to a vertical line running through the entity and the title lead.
distance
The distance from the entity to the anchor point.
entitytypename
The name of the entity to which the title is attached.
entityid
The ID of the entity to which the title is attached.
None.
