HMIN_load_writetemperature()
Writes a temperature to hmlib.
void HMIN_load_writetemperature(HM_entityidtype id, unsigned char type, HM_entityidtype nodeid, HM_entityidtype systemid, double temperature, HM_entityidtype loadcollectorid);
HyperMesh hminlib Function
id
The ID of the temperature.
type
The type of the temperature, a user-defined value.
nodeid
The ID of the node where the temperature is applied.
systemid
The ID of the system in which the temperature is applied.
temperature
The temperature to be applied.
loadcollectorid
The ID of the collector in which the temperature is applied.
None.
