HMIN_load_writeacceleration()
Writes an acceleration to hmlib.
void HMIN_load_writeacceleration(HM_entityidtype id, unsigned char type, HM_entityidtype nodeid, HM_entityidtype systemid, double xcomp, double ycomp, double zcomp, HM_entityidtype loadcollectorid);
HyperMesh hminlib Function
id
The ID of the acceleration.
type
The type of the acceleration, a user-defined value.
nodeid
The ID of the node where the acceleration is applied.
systemid
The ID of the system in which the acceleration is applied.
xcomp
The x component of the acceleration.
ycomp
The y component of the acceleration.
zcomp
The z component of the acceleration.
loadcollectorid
The ID of the load collector to which the acceleration belongs.
None.
