HV-3095: Generate CFD Plots/Streamlines
Learn how to generate cross sections for contour plotting of flow variables (for example, velocity or pressure) and generate streamlines starting from a surface or line.
- Click the Streamlines panel button
on the Result toolbar.
OR
- Select from the menu bar.
The Streamlines panel allows you to generate streamlines using any available nodal vector field (typically a velocity field). Velocity fields are directly written to H3D files by many solvers such as: Radioss, HyperXtrude, Moldflow, etc. Velocity fields and other scalar and vector data fields are also saved in EnSight format by most CFD solvers.
from the Result toolbar to enter the Streamlines
panel.
