HV-3080: Create Linear Superposition Loadsteps
Learn how to create a linear superposition loadstep from existing loadsteps and contour a linear superposition loadstep.
- Right-click in the Results Browser and select .
OR
- Click the Derived Load Cases button
on the Result toolbar and
set the Type to
Linear-Superposition. OR
- Select from the menu bar and set the Type to Linear-Superposition.
This utility allows you to create linear superposition loadsteps using existing loadsteps and their simulation steps. Linear superposition loadsteps are saved to the session file. Using this utility, you can also create derived loadsteps and envelope loadsteps. See the Derived Load Cases topic for additional information.
, to append these selected loadsteps to the new linear
