Output Blocks Panel
Use the Output Blocks panel to create and update blocks of entities used for output requests.
Output blocks can be created for nodes, elements, components, systems, entity sets, properties, groups, materials, and assemblies.
Panel Options
Option Action
name = Specify a name for a new output block, or double-click this button to select an existing output block.
entity switch Select the entities to be grouped into the output block.
Command Buttons
Button Action
create Create the new output block.
edit Open the output block's card image in edit mode.
update Update the selected output block to contain the entities selected via the entity selector.
review Click review and select one and the entities that belong to the output block. The entity is highlighted in the modeling window.
return Exit the panel.
