Spin Panel
Use the Spin panel to create a surface and/or mesh or elements by spinning a series of nodes, a line or lines, or a group of elements about a vector to create a circular structure.
Spin Geoms Subpanel
Use the Spin Geoms subpanel to create a surface and/or mesh or elements by spinning a series of nodes, a line, or lines about the normal of a user-defined plane.
Option Action
node list / lines selector Select the nodes/lines to spin.
N1, N2, N3, B Select a plane.
The selected nodes are spun about the normal of the plane.
angle Specify the angle through which to spin the nodes.
meshing options
mesh, keep surf
Create a surface from the selected entities and generate a mesh on the created surface.
The created surface is retained along with the mesh.
mesh, dele surf
The created surface is deleted and only the corresponding mesh is retained.
mesh w/o surf
Create a mesh between the selected entities using linear interpolation without creating a surface.
surface only
Create a surface from selected entities, but do not generate a mesh.
Use the resulting surface to perform any desired geometry cleanup functions or automeshing.
Spin Elems Subpanel
Use the Spin Elems subpanel to create a surface and/or mesh or elements by spinning a group of elements about the normal of a user-defined plane.
Option Action
elems selector Select the elements to spin.
The elements are spun about the normal of the plane.
angle Specify the angle through which to spin the elements.
on spin Specify the number of elements to generate along the path of the spin.
bias style Select a bias style.
bias intensity Specify a bias intensity.
Command Buttons
Option Action
spin + Create the surfaces in the direction specified.
spin - Create the surfaces in the opposite direction.
reject Revert the most recent changes.
return Exit the panel.
Spin Nodes to Create a Surface
Figure 1. Nodes Selected
Figure 2. Base Node Selected
Figure 3. Surface Created
Spin Lines to Create a Surface
Figure 4. Nodes Selected
Figure 5. Base Point Selected
Figure 6. Surface Created
Spin Elements to Create a Surface
Figure 7. Elements Selected
Figure 8. Base Point Selected
Figure 9. Surface Created
Spin a Group of Elements to Create a Surface
Figure 10. Elements Selected
Figure 11. Base Point Selected
Figure 12. Elements Created using Spin+. The elements were created using spin +, with a negative biasing value.
Figure 13. Elements Created without Element Biasing
