By Width
Use the By Width option in the Extended Entity Selection menu to select surfaces based on their width.
By Example Subpanel
Use the By Example subpanel to select a sample surface and find the surfaces in your model with similar widths.
Option Action
surf Select a sample surface.
closed loops only Systematically disregard surfaces that do not form a closed loop.
has free edges Surfaces must have at least one free edge to be selected.
By Value Subpanel
Use the By Value subpanel to specify a range of values for width and find the surfaces that match this range, while taking into account any filtering options that are enabled.
Option Action
min width Enter the minimum width of the surface to find.
max width Enter the maximum width of the surface to find.
Command Buttons
Button Action
select Select the surfaces highlighted.
reject Reject the current selections.
return Exit the panel.
