Color Panel
Use the Color panel to change the color attributes of a collector.
Color can only be specified by collector. For example, if a collector is designated to be blue, the lines and elements belonging to that collector are also blue.
Only entities that are valid for the entity selector can be colored (but black is not a valid color for collectors). All other entities derive their color from their parent collector.
Panel Options
Option Action
entity selector Select colors for translation.
color Select a color.
set color Set the color of the selected collector.
auto color Automatically change the color of most collectors in the model.
This option applies to collectors currently using colors 9 through 16 (gray), as well as colors 1 (black) and 2 (white).
You do not have to select collectors first.
