/MAT/LAW80
Block Format Keyword This law allows modeling the ultra-high strength steel behavior at high temperatures and the phase transformation phenomena from austenite to ferrite, pearlite, bainite and martensite during cooling.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) | (9) | (10) | |
/MAT/LAW80/mat_ID/unit_ID | ||||||||||
mat_title | ||||||||||
E | fct_IDE | YscaleE | Time_unit | |||||||
Fsmooth | Fcut | Ceps | Peps | |||||||
tab_IDY1 | tab_IDY2 | tab_IDY3 | tab_IDY4 | tab_IDY5 | ||||||
Yscale1 | Yscale2 | Yscale3 | Yscale4 | Yscale5 | ||||||
Xscale1 | Xscale2 | Xscale3 | Xscale4 | Xscale5 | ||||||
Θ2 | Θ3 | Θ4 | Θ5 | |||||||
Alpha1 | Alpha2 | Iflag_T | fct_ID_T | Iflag_loc | ||||||
QR2 | QR3 | QR4 | Alpha | Tref | ||||||
Gsize | ||||||||||
KF | KP | Lat1 | Lat2 | Tini | ||||||
B | Mo | Mn | W | Al | ||||||
C | Cr | Si | Cu | As | ||||||
Co | Ni | V | P | Ti |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density (Real) |
E | Young's modulus (Real) |
Poisson's ratio (Real) |
fct_IDE | Function identifier for temperature
dependent Young's modulus. (Integer) |
YscaleE | Scale factor for ordinate (Young) for
fct_IDE. Default = 1.0 (Real) |
Time_unit | Number of time units per hour. Default corresponds to seconds, equals 3600 time units per hour. Defaults = 3600 (Real) |
Fsmooth | Smooth strain rate option flag.
(Integer) |
Fcut | Cutoff frequency for strain rate
filtering. Default = 1030 (Real) |
Ceps | Parameter for the effective strain rate
dependency (Cowper Symonds relation). 2 (Real) |
Peps | Parameter for the effective strain rate
tab_IDY1 | Table identifier for yield stress, first
entry effective plastic strain and second temperature, for
austenite. (Integer) |
tab_IDY2 | Table identifier of yield stress for
ferrite. (Integer) |
tab_IDY3 | Table identifier of yield stress for
pearlite. (Integer) |
tab_IDY4 | Table identifier of yield stress for
bainite. (Integer) |
tab_IDY5 | Table identifier of yield stress for
martensite. (Integer) |
Yscale1 | Scale factor for ordinate (stress) for
tab_IDY1. Default = 1.0 (Real) |
Yscale2 | Scale factor for ordinate (stress) for
tab_IDY2. Default = 1.0 (Real) |
Yscale3 | Scale factor for ordinate (stress) for
tab_IDY3. Default = 1.0 (Real) |
Yscale4 | Scale factor for ordinate (stress) for
tab_IDY4. Default = 1.0 (Real) |
Yscale5 | Scale factor for ordinate (stress) for
tab_IDY5. Default = 1.0 (Real) |
Xscale1 | Scale factor for third variable strain
rate for tab_IDY1. Default = 1.0 (Real) |
Xscale2 | Scale factor for third variable strain
rate for tab_IDY2. Default = 1.0 (Real) |
Xscale3 | Scale factor for third variable strain
rate for tab_IDY3. Default = 1.0 (Real) |
Xscale4 | Scale factor for third variable strain
rate for tab_IDY4. Default = 1.0 (Real) |
Xscale5 | Scale factor for third variable strain
rate for tab_IDY5. Default = 1.0 (Real) |
Θ2 | Memory coefficient that determines the
fraction of previous straining in the austenite that will be remembered in the newly
formed ferrite.
(Real) |
Θ3 | Memory coefficient that determines the
formed pearlite.
(Real) |
Θ4 | Memory coefficient that determines the
formed bainite.
(Real) |
Θ5 | Memory coefficient that determines the
formed martensite.
(Real) |
Alpha1 | Thermal expansion coefficient for austenite (gamma phase) | |
Alpha2 | Thermal expansion coefficient for products (alpha phase). | |
Iflag_T | Heating process. 5
fct_ID_T | Cooling and heating function identifier.
Only used, if Iflag_T=2. 5
(Integer) |
Iflag_loc | Flag to activate the phase
transformation per element depending on temperature variation. 6
(Integer) |
QR2 | Activation energy divided by the
universal gas constant (R=8.314472) for the diffusion reaction of the austenite
ferrite reaction. 1 Default = 11575 (Real) |
QR3 | Activation energy divided by the
pearlite reaction. 1 Default = 13840 (Real) |
QR4 | Activation energy divided by the
bainite reaction. 1 Default = 13588 (Real) |
Alpha | Material constant for martensite phase.
3 (Real) |
Tref | Reference temperature for thermal
expansion. (Real) |
Time necessary to start transformation
during heating at temperature T =
(starting point of austenization). 7 (Real) |
(final point of austenization). 7 (Real) |
Gsize | ASTM grain size number for the
austenite. (Real) |
KF | Coefficient of Boron in the composition
of ferrite. 4 (Real) |
KP | Coefficient of Boron in the composition
of pearlite. 4 (Real) |
Lat1 | Latent heat for the decomposition of
austenite to ferrite, pearlite, and bainite. (Real) |
Lat2 | Latent heat for the decomposition of
austenite to martensite. (Real) |
Tini | Initial
temperature. (Real) |
B | Boron percentage weight in material
(0.0~1.0). (Real) |
Mo | Molybdenum percentage weight in material
(0.0~1.0). (Real) |
Mn | Manganese percentage weight in material
(0.0~1.0). (Real) |
W | Tungsten percentage weight in material
(0.0~1.0). (Real) |
Al | Aluminum percentage weight in material
(0.0~1.0). (Real) |
C | Carbon percentage weight in material
(0.0~1.0). (Real) |
Cr | Chromium percentage weight in material
(0.0~1.0). (Real) |
Si | Silicon percentage weight in material
(0.0~1.0). (Real) |
Cu | Copper percentage weight in material
(0.0~1.0). (Real) |
As | Arsenic percentage weight in material
(0.0~1.0). (Real) |
Co | Cobalt percentage weight in material
(0.0~1.0). (Real) |
V | Vanadium percentage weight in material
(0.0~1.0). (Real) |
P | Phosphorous percentage weight in
material (0.0~1.0). (Real) |
Ti | Titanium percentage weight in material
(0.0~1.0). (Real) |
Ni | Nickel percentage weight in material
(0.0~1.0). (Real) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW80/1/1
steel
# RHO_I
7.8E-9
# E Nu Fct_IDE YscaleE Time_unit
210000 .3 0 0 3600
# Fsmooth Fcut Ceps Peps
0 0 0 0
# TAB_IDY1 TAB_IDY2 TAB_IDY3 TAB_IDY4 TAB_IDY5
10 10 10 10 10
# Yscale1 Yscale2 Yscale3 Yscale4 Yscale5
0 0 0 0 0
# Xscale1 Xscale2 Xscale3 Xscale4 Xscale5
0 0 0 0 0
# Theta2 Theta3 Theta4 Theta5
0 0 0 0
# Alpha1 Alpha2 Iflag_T fct_ID_T Iflag_loc
2.51E-5 1.11E-5 0 0 0
# QR2 QR3 QR4 Alpha Tref
13022 15569 15287 .011 298.14999
# tau1 tau3 Gsize
8
# KF KP Lat1 Lat2 Tini
190000 31000 590 640 1083
# B Mo Mn W Al
.0025 0 1.23 0 0
# C Cr Si Cu As
.248 .24 .29 0 0
# Co Ni V P Ti
0 0 0 .015 0
/TABLE/1/10
table
3
2011 0.0 273.
2013 0.02 300.
2013 0.04 300.
2012 0.0 300.
2012 0.02 273.
2012 0.04 273.
/FUNCT/2011
1st
0.0 185.0
0.1 339.0
1.0 339.0
/FUNCT/2012
2nd
0.0 190.0
0.1 344.0
1.0 344.0
/FUNCT/2013
3rd
0.0 195.0
0.1 349.0
1.0 349.0
#ENDDATA
/END
- If Q should be in , then 1 cal =4.1855 J.
- The strain rate dependency when Cowper
Seymonds is used:
(1) - The martensite volume fraction
equation is:
(2) Where,- Temperature of martensite transformation
- Fraction of austenite available when the transformation of martensite starts
- In order to take into account the Boron added in the composition of the material, the functions of ferrite and pearlite are modified: the coefficients KF and KP, multiplies the weight percentage of Boron (B), respectively in ferrite and pearlite composition functions.
- By default, this law considers dealing
with a cooling process. Iflag_T can be used to define if heating or
cooling is simulated as:
- Iflag_T = 0: Cooling - Austenite transforms to product phase (martensite)
- Iflag_T = 1: Heating - Austenite is formed from ferrite
- Iflag_T = 2: Cooling and heating is flag is defined as a function of time with using fct_ID_T. Cooling occurs when the function is 0 and heating occurs when the function is 1.
- Flag for global or local phase
transformation:
- Iflag_loc = 2 (default) phase change is global per part depending on the Iflag_T.
- Iflag_loc = 1 phase change is treated automatically per element respecting its temperature variation in time. In this case, Iflag_T is used only for initialization of phase fractions values and only at time=0.
- The Austenization model is based on a
modified Leblond model 1; where
is the fraction of austenite.
(3) Where,
- Temperature.
- Starting temperature of austenization.
- Final temperature of austenization.
The starting and final temperatures of austenization are calculated automatically based on the composition of the steel and written to the Starter output file.
- This law can be used with /HEAT/MAT.
- This law is compatible with /PROP/TYPE1, /PROP/TYPE9, and /PROP/TYPE10.
- List of Animation output (/ANIM/SHELL/USRII/JJ):
- USR 2= Austenite Phase Fraction
- USR 3= Ferrite Phase Fraction
- USR 4= Pearlite Phase Fraction
- USR 5= Bainite Phase Fraction
- USR 6= Martensite Phase Fraction
- USR 7= Hardness
- USR 8= Temperature
- USR 9= Yield
- USR 10= XGAMA in martensite equation
- Material phase transformations will occur only during the cooling. There is no material phase transformation due to deformation or heating.
