/MAT/LAW93 (ORTH_HILL) or (CONVERSE)
Block Format Keyword This law describes the orthotropic elastic behavior material with Hill plasticity and is applicable to shell and solid elements (/BRICK, /TETRA4 and /TETRA10).
It could be used with property set /PROP/TYPE11, /PROP/TYPE17, /PROP/TYPE51, /PROP/PCOMPP for shell and /PROP/TYPE6 for solid.
/MAT/LAW93/mat_ID/unit_ID or /MAT/ORTH_HILL/mat_ID/unit_ID or /MAT/CONVERSE/mat_ID/unit_ID/ | |||||||||
mat_title | |||||||||
E11 | E22 | E33 | G12 | ||||||
G13 | G23 | ||||||||
Nrate |
fct_IDi | Fscalei |
QR1 | CR1 | QR2 | CR2 |
R11 | R22 | R12 | |||||||
R33 | R13 | R23 |
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material title. (Character, maximum 100 characters) |
Initial density. (Real) |
E11 | Young’s modulus in direction
11. (Real) |
E22 | Young’s modulus in direction
22. (Real) |
E33 | Young’s modulus in direction
33. (Real) |
G12 | Shear modulus in direction
12. (Real) |
G13 | Shear modulus in direction 13.
(Real) |
G23 | Shear modulus in direction 23.
(Real) |
Poisson's ratio 12. (Real) |
Poisson's ratio 13. (Real) |
Poisson's ratio 23 (Real) |
Nrate | Number of yield function. | |
fct_IDi | Plasticity curves ith function
identifier (i=1,
Nrate). (Integer) |
Fscalei | Scale factor for ith function (i=1,
Nrate). Default = 1.0 (Real) |
Strain rate for ith function (i=1,
Nrate). (Real) |
Initial yield stress. Default = 1E30 (Real) |
QR1 | Parameter of hardening. Default = 0.0 (Real) |
CR1 | Parameter of hardening. Default = 0.0 (Real) |
QR2 | Parameter of hardening. Default = 0.0 (Real) |
CR2 | Parameter of hardening. Default = 0.0 (Real) |
R11 | Lankford parameter in direction 11. Default = 1E30 (Real) |
R22 | Lankford parameter in direction 22. Default = 1E30 (Real) |
R33 | Lankford parameter in direction 33. Default = 1E30 (Real) |
R12 | Lankford parameter in direction 12. Default = 1E30 (Real) |
R13 | Lankford parameter in direction 13. Default = 1E30 (Real) |
R23 | Lankford parameter in direction 23. Default = 1E30 (Real) |
Example (Curve Input)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
#- 2. MATERIALS:
/MAT/LAW93/1/1
plastic
# RHO_I
1.111E-6
# E11 E22 E33 G12 Nu12
1.111 1.111 1.111 1.111 0.11
# G13 G23 Nu13 Nu23
1.111 1.111 0.11 0.11
# Nrate
2
# Ifunct Yscale Epsdot
141 0.001 0.1
141 0.002 0.2
# SigY QR1 CR1 QR2 CR2
0.0 0.0 0.0 0.0 0.0
# R11 R22 R12
.11 .11 .11
# R33 R13 R23
.11 .11 .11
/FUNCT/141
plasticity curve
# X Y
0.000 26.900000
0.005000 46.700000
0.015000 69.100000
0.025000 84.300000
0.035000 94.500000
0.045000 101.20000
0.055000 106.10000
0.065000 110.00000
0.075000 113.60000
0.085000 117.10000
0.095000 120.50000
0.105000 124.00000
0.112000 126.30000
#ENDDATA
- The yield stress is defined by a user function
and the yield stress is compared to equivalent
stress in the orthotropic frame.
(1) Where,(2) (3) (4) (5) Two different ways (parameter input or curve input) to describe the Yield criteria in LAW93. The yield will be compared with equivalent stress as:(6) - For parameter input, the hardening can be
defined as:
(7) - Using curve input, the parameter input will be
ignoredThe Yield can be defined with using stress versus plastic strain curve taking account the strain rate effect. When the stress versus strain curves are defined this is the default way for defining the hardening.
- If , the yield is interpolated between and .
- If function, is used.
- Above , yield is extrapolated.
defined as:
