SWLDPRM, GSMOVE
Bulk Data Entry Maximum number of times GS for the CWELD (PARTPAT or ELPAT format) or GS/GE for the CSEAM is moved in cases when not all auxiliary points have projections onto the patch of shells.
| Parameter | Values | Description |
| GSMOVE | Integer ≥ 0 Default = 0 |
Maximum number of times GS for the CWELD (PARTPAT or ELPAT format) or GS/GE for the CSEAM is moved in cases when not all auxiliary points have projections onto the patch of shells. |
