DRESP1 - Static Stress/Strain Item Codes
Element Stress/Strain Item ASCII Code Number Code 1
CELAS Stress/Strain S 2
CROD Both ends SAB -
  End A SA 2
  End B SB 2
CBAR 2 All stresses/strains SALL -
  End A pt. C SAC 2
  End A pt. D SAD 3
  End A pt. E SAE 4
  End A pt. F SAF 5
  End B pt. C SBC 10
  End B pt. D SBD 11
  End B pt. E SBE 12
  End B pt. F SBF 13
  Axial end A SAX -
  Axial end B SBX -
  Max end A SAMAX 7
  Max end B SBMAX 14
CBEAM 2 All stresses/strains SALL -
  End A pt. C SAC 4
  End A pt. D SAD 5
  End A pt. E SAE 6
  End A pt. F SAF 7
  End B pt. C SBC 104
  End B pt. D SBD 105
  End B pt. E SBE 106
  End B pt. F SBF 107
  Axial end A SAX -
  Axial end B SBX -
  Max end A SAMAX 8
  Max end B SBMAX 108
CSHEAR Maximum Shear SHMAX 2
Average Shear SHAVG 3
Safety Margin SHMRG 4
All Solid elements von Mises SVM 13
  Signed von Mises SSVM -
  Max Principal Stress SMP -
  Major Principal SMAP 8
  Mid Principal SMDP 16
  Minor Principal SMIP 22
  Normal X SXX 6
  Normal Y SYY 14
  Normal Z SZZ 20
  Shear XY SXY 7
  Shear YZ SYZ 15
  Shear XZ SXZ 21
  Equivalent Plastic Strain PLAS -
  Surface Stress (von Mises) SVMS 3 -
  Surface Stress (Max Principal Stress) SMPS 3 -
  Surface Stress (Minor Principal) SMIPS 3 -
  Neuber correction NEUB -
All Shell elements von Mises both surfaces SVMB -
  Major Principal both surfaces SMPB -
  von Mises 1 SVM1 9
  von Mises 2 SVM2 17
  Signed von Mises both surfaces SSVMB -
  Signed von Mises 1 SSVM1 -
  Signed von Mises 2 SSVM2 -
  Major Principal 1 SMP1 7
  Major Principal 2 SMP2 15
  Minor Principal both surfaces SMIPB -
  Minor Principal 1 SMIP1 8
  Minor Principal 2 SMIP2 16
  Normal X both surfaces SXB -
  Normal X 1 SX1 3
  Normal X 2 SX2 11
  Normal Y both surfaces SYB -
  Normal Y 1 SY1 4
  Normal Y 2 SY2 12
  Shear XY both surfaces SXYB -
  Shear XY 1 SXY1 5
  Shear XY 2 SXY2 13
  Equivalent Plastic Strain both surfaces PLASB -
  Equivalent Plastic Strain 1 PLAS1 -
  Equivalent Plastic Strain 2 PLAS2 -
  Neuber correction both surfaces NEUBB -
  Neuber correction 1 NEUB1 -
  Neuber correction 2 NEUB -
1 OptiStruct provides partial support for Nastran item codes. Since Nastran response items are not fully compatible with those used in OptiStruct, it is recommended that the OptiStruct ASCII item codes be used.
2 For Bar elements that reference PBARL, PBEAML, it is recommended that the special stress item codes listed under DRESP1 - Static Stress Item Codes for Bar Elements using PBARL, PBEAML Properties be used. Stress/strain items listed here for CBAR and CBEAM elements using PBAR, PBEAM, PBARL, or PBEAML properties include only normal stress/strain.
3 Surface Stress Item codes are not supported for RTYPE=GPSTR.
