/PROP/TYPE29, /PROP/TYPE30 or /PROP/TYPE31
Block Format Keyword Describes the user's property set.
/PROP/TYPE29/prop_ID, /PROP/TYPE30/prop_ID or /PROP/TYPE31/prop_ID
prop_title
prop_ID Property identifier
(Integer, maximum 10 digits)
prop_title Property title
  1. Type USER1 (TYPE29), USER2 (TYPE30), and USER3 (TYPE31) are properties that may be created by you.
  2. User Types can only be affected to solid or spring elements.
  3. For Program User Properties, contact Altair Development France.
