/PROP/TYPE0 (VOID)
Block Format Keyword This property is used to define the void property set.
/PROP/TYPE0/prop_ID/unit_ID or /PROP/VOID/prop_ID/unit_ID
prop_title
Optional line
Thick
prop_ID Property identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
prop_title Property title
Thick Thickness
(Real)
[ m ]
  1. Void property is only compatible with void material.
  2. An optional format is available.
  3. This additional data allows to define contact interfaces with void material and property: all kinds of input for interfaces will then be available (Igap =1, Stfac as a stiffness factor).
  4. Contact stiffness will be correctly calculated only when Thick is entered. If there is no thickness entered, the elements with this property will have no contact stiffness.
