/MAT/LAW15 (CHANG)
Block Format Keyword This law is used to model composite shell elements, similar to LAW25. The plastic behavior is based on the Tsai-Wu criteria (/MAT/LAW25 (COMPSH) for Tsai-Wu description) and failure is based on the Chang-Chang failure criterion is used.
It is recommended to use material LAW25 in combination with a separate Chang-Chang failure criteria (/MAT/LAW25 with /FAIL/CHANG keywords), instead of material LAW15.
/MAT/LAW15/mat_ID/unit_ID or /MAT/CHANG/mat_ID/unit_ID
mat_title
ρiρi
E11 E22 ν12
G12 G23 G31
b n fmax
Wmaxp Wrefp Ioff
σt1y σt2y σc1y σc2y α
σc12y σt12y c ˙ε0 ICC
β τmax S1 S2 S12
Fsmooth Fcut C1 C2
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρi Initial density.
(Real)
[kgm3]
E11 Young's modulus in direction 1.
(Real)
[Pa]
E22 Young's modulus in direction 2.
(Real)
[Pa]
ν12 Poisson's ratio.
(Real)
G12 Shear modulus.
(Real)
[Pa]
G23 Shear modulus.
(Real)
[Pa]
G311 Shear modulus.
(Real)
[Pa]
b Hardening parameter.
(Real)
n Hardening exponent.
Default = 1.0 (Real)
fmax Maximum value of yield function. 2
Default = 1030 (Real)
[Pa]
Wmaxp Maximum plastic energy per volume unit.
[Jm3]
Wrefp Reference plastic energy per volume unit.
[Jm3]
Ioff Total element failure criteria. 4
= 0
Shell is deleted if W*p>Wmax*p for one layer.
= 1
Shell is deleted if W*p>Wmax*p for all layers.
= 2
If for each layer, W*p>Wmax*p or tensile failure in direction 1
= 3
If for each layer, W*p>Wmax*p or tensile failure in direction 2.
= 4
If for each layer, W*p>Wmax*p or tensile failure in directions 1 and 2.
= 5
If for all layers: W*p>Wmax*p or tensile failure in direction 1
or if for all layers: W*p>Wmax*p or tensile failure in direction 2.
= 6
If for each layer, W*p>Wmax*p or tensile failure in direction 1 or 2.
(Integer)
σt1y Composite yield stress in tension in direction 1. 2
(Real)
[Pa]
σt2y Composite yield stress in tension in direction 2.
(Real)
[Pa]
σc1y Composite yield stress in compression in direction 1.
(Real)
[Pa]
σc2y Composite yield stress in compression in direction 2.
(Real)
[Pa]
α F12 reduction factor. 2
Default set to 1.0 (Real)
σc12y Yield stress in shear and strain rate compression in direction 12.
(Real)
[Pa]
σt12y Yield stress in shear and strain rate tension in direction 12.
(Real)
[Pa]
c Yield stress in shear and strain rate coefficient. 2
= 0
No strain rate dependency.
(Real)
˙ε0 Yield stress in shear and strain rate reference.
(Real)
[1s]
ICC Strain rate computation flag. 2
= 1 (Default)
Strain rate effect on fmax no effect on Wmaxp .
= 2
No strain rate effect on fmax and Wmaxp
= 3
Strain rate effect on fmax and Wmaxp .
= 4
No strain rate effect on fmax effect on Wmaxp .
(Integer)
β Shear scaling factor. 1
(Real)
τmax Time relaxation. 3
[s]
S1 Longitudinal tensile strength. 1
[Pa]
S2 Transverse tensile strength.
[Pa]
S12 Shear strength.
[Pa]
Fsmooth Smooth strain rate option flag.
= 0 (Default)
No strain rate smoothing
= 1
Strain rate smoothing active
(Integer)
Fcut Cutoff frequency for strain rate filtering.
[Hz]
C1 Longitudinal compressive strength. 1
[Pa]
C2 Transverse compressive strength.
[Pa]
Example (Carbon)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                  mm                  ms
#-  2. MATERIALS:
/MAT/LAW15/1/1
Carbon
#              RHO_I
              1.8E-6                   0
#                E11                 E22                nu12
                  41                 3.3                  .3
#                G12                 G23                 G31
                 5.2                 1.3                 1.3
#                  b                   n                fmax
                8E-6                   1              100000
#              Wpmax              Wpref       Ioff
              100000                   0         0
#          sigma_1yt           sigma_2yt           sigma_1yc          sigma_2yc               alpha
                .786               .1566                .786               .1566                   0
#         sigma_12yc          sigma_12yt                   c           Eps_dot_0       ICC
               .0655               .0655                   0                   0         0
#               beta                Tmax                  S1                  S2                 S12
                   1                 .01                   0                   0                   0
#  Fsmooth                Fcut                  C1                 C12
         0                   0                   0                   0
#ENDDATA
/END
  1. Chang-Chang failure criteria
    Six material parameters are used in the Chang-Chang failure criteria to describe the two different failure behaviors.
    • For fiber breakage, the failure criteria is:
      • Tensile fiber mode σ11>0
        (1)
        e2f=(σ11S1)2+β(σ12S12)21.0
        0failed<0elasticplastic
      • Compressive fiber mode σ11<0
        (2)
        e2c=(σ11C1)21.0
    • For matrix cracking, the failure criteria is:
      • Tensile fiber mode σ22>0
        (3)
        e2m=(σ22S2)2+β(σ12S12)21.0
      • Compressive matrix mode σ22<0
      (4)
      e2d=(σ222S12)2+[(C22S12)21]σ22C2+(σ12S12)21.0
  2. Before failed (damage parameter ef2,ec2,em2,ed2 is less than 0), material is in elastic–plastic phase. The plastic behavior is based on the TSAI-WU criteria (see Tsai-Wu Formulation (Iform =0) for Tsai-Wu criterion description).
  3. After failed (damage parameter ef2,ec2,em2,ed2 is greater than or equal to 0), the stresses are decreased by using an exponential function to avoid numerical instabilities.
    A relaxation technique is used by gradually decreasing the stress.(5)
    σ(t)=f(t)σd(tr)
    With function of relaxation:
    f(t)=exp(ttrτmax) and ttr
    Where,
    t
    Time
    tr
    Start time of relaxation when the damage criteria is assumed
    τmax
    Time of dynamic relaxation
    σd(tr)
    Stress components at the beginning of damage
  4. If a shell has several layers with one material per layer (different materials, different Ioff), the Ioff used is the one which is associated to the shell in the shell element definition.
