/INIQUA/ENER
Block Format Keyword Describes the initial state for a quad.
/INIQUA/ENER/unit_ID
quad_ID   value
unit_ID Unit Identifier.
(Integer, maximum 10 digits)
quad_ID Element identifier.
(Integer)
value Data value.
(Real)
  1. The internal energy is expressed by volume unit.
  2. The initial state for quad may be defined by more than one block.
