/CYL_JOINT
Block Format Keyword Defines cylindrical joints.
/CYL_JOINT/joint_ID/unit_ID
joint_title
node_ID1 node_ID2 grnd_ID
joint_ID Joint identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
joint_title Joint title.
node_ID1 Node identifier N1.
(Integer)
node_ID2 Node identifier N2.
(Integer)
grnd_ID Node group identifier.
(Integer)
  1. A cylindrical joint behaves like a rigid body; except for the translational DOF in a variable direction and the rotational DOF around this direction.
  2. The direction is defined by node_ID1 and node_ID2.
  3. node_ID1 and node_ID2 belong to the cylindrical joint.
  4. At each time step, the center of mass and moment of inertia of the joint are computed.
  5. The grnd_ID input is obligatory. The cylindrical joint will only be applied to nodes belonging to a node group.
