/BRIC20
Block Format Keyword Describes 3D solid elements (20 node brick elements). This quadratic element should be used with the property /PROP/SOLID.
/BRIC20/part_ID | |||||||||
bric_ID | node_ID1 | node_ID2 | node_ID3 | node_ID4 | node_ID5 | node_ID6 | node_ID7 | node_ID8 | |
node_ID9 | node_ID10 | node_ID11 | node_ID12 | node_ID13 | node_ID14 | node_ID15 | node_ID16 | ||
node_ID17 | node_ID18 | node_ID19 | node_ID20 |
Field | Contents | SI Unit Examples |
part_ID | Part identifier of the
block (Integer, maximum 10 digits) |
bric_ID | Element
identifier (Integer) |
node_ID1 | Node identifier
1 (Integer) |
node_ID2 | Node identifier
2 (Integer) |
node_ID3 | Node identifier
3 (Integer) |
node_ID4 | Node identifier
4 (Integer) |
node_ID5 | Node identifier
5 (Integer) |
node_ID6 | Node identifier
6 (Integer) |
node_ID7 | Node identifier
7 (Integer) |
node_ID8 | Node identifier
8 (Integer) |
node_ID9 | Node identifier
9 (Integer) |
node_ID10 | Node identifier
10 (Integer) |
node_ID11 | Node identifier
11 (Integer) |
node_ID12 | Node identifier
12 (Integer) |
node_ID13 | Node identifier
13 (Integer) |
node_ID14 | Node identifier
14 (Integer) |
node_ID15 | Node identifier
15 (Integer) |
node_ID16 | Node identifier
16 (Integer) |
node_ID17 | Node identifier
17 (Integer) |
node_ID18 | Node identifier
18 (Integer) |
node_ID19 | Node identifier
19 (Integer) |
node_ID20 | Node identifier
20 (Integer) |
- The identifier (ID) must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- The 20 node brick elements must have a different identifier one from each other.
- The 20 node brick elements are treated internally as solid elements (bric_ID), using solid materials and solid groups (grbric_ID).
- If nodes 9 to 20 are set to zero, a
linear behavior is assumed on the corresponding edge.
