/PENTA6
Block Format Keyword This pentahedron element is currently only supported as a thick shell Isolid =15 element and used with /PROP/TYPE20 (TSHELL). For non-thick shell solid 3D pentahedron elements, create a degenerated /BRICK element.
/PENTA6/part_ID | |||||||||
penta_ID | node_ID1 | node_ID2 | node_ID3 | node_ID4 | node_ID5 | node_ID6 |
Field | Contents | SI Unit Examples |
part_ID | Part identifier of the
block. (Integer, maximum 10 digits) |
penta_ID | Element
identifier (Integer) |
node_ID1 | Node identifier
1 (Integer) |
node_ID2 | Node identifier
2 (Integer) |
node_ID3 | Node identifier
3 (Integer) |
node_ID4 | Node identifier
4 (Integer) |
node_ID5 | Node identifier
5 (Integer) |
node_ID6 | Node identifier
6 (Integer) |
- The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- This option defines a pentahedron, which is only
available with Isolid =15 (PA6 thick shell element formulation
/DEF_SOLID).
