Convert Data for use with Parallel AcuFieldView
When using AcuFieldView with parallel server processes, the distribution of elements among the processes is controlled by the regions that are present in the FV-UNS file.
The regions are sequentially distributed to each of the parallel processes. To obtain optimal balance of the parallel post-processing, it is necessary to convert the data to FV-UNS using the -fvr subdomain option.
More information regarding the use of AcuTrans is available in the AcuSolve Programs Reference Manual.
