Convert Poincare Results into FieldView Particle Path File Format
Poincare results are produced using the POINCARE_OUTPUT type from AcuTrace.
acuTransTrace -to fieldview -fvopt poincare,steady
acuTransTrace -to fieldview -fvopt poincare,steady,pseudotc
The "steady" argument passed to the -fvopt option causes the data to be written in FieldView's ASCII particle path file format. This option must be used when converting poincare output.
