TensorFromScalar
Creates a 3D tensor from six scalar tables and stores the result in answer.
xx
A scalar value table.
yy
zz
xy
yz
zx
sysid
A system ID or keyword (default = 0).
Outputs
answer
A tensor value table.
  • xx, yy, zz, xy, yz, zx and answer must be bound to the same entity type and of the same domain (complex or real).
  • sysid is a string containing an ID or keyword that defines the system the tensor will be created relative to:
    • “0”: Global (the default)
    • A positive integer: a system ID in the model
    • “elem”: the elemental coordinate system
    • “anal”: the nodal analysis system
    • “ply”: the elemental ply system
    • “mat”: the elemental material system
  • If xx is a constant value table (created by the Constant operator), no records will be added to the answer table.
  • If a record cannot be found in all six input scalar tables, no tensor will be created.
TensorFromScalar(xs,ys,zs,xys,yzs,zxs)
XML Example
<call name="TensorFromScalar" xx="xs_tab" yy="ys_tab"
zz="zs_tab" xy="xys_tab" yz="yzs_tab" zx="zxs_tab"
answer="ans_tab" />
