CFD Post-Processing
HyperView offers CFD post-processing capabilities for a large class of industrial applications.
CFD results from AcuSolve can be loaded into HyperView via the native AcuSolve result reader (*.log file) or by using the Ensight reader. When using the Ensight reader, use AcuTrans to convert the AcuSolve results into the Ensight format.
The direct Ensight reader in HyperView allows you to import results from all major CFD solvers.
The following functionalities are available for CFD post-processing:
  • Streamlines
  • Contour
  • Iso Value
  • Vector Plot
