Arithmetic Operators
Arithmetic operators contain both unary and binary operations.
Unary Operators
Unary operators have two parameters: src and answer. Both of these parameters follow the syntax based upon the equation below:
{op}(src) = answer
where:
op
The unary operation: Inverse (inv), SquareRoot (sqrt), Power (^), etc.
src
The input table to the operator op.
answer
Contains the result if the operation is successful.
Binary Operators
Binary operators follow a syntax based upon the following equation:
lhs {op} rhs = answer
where:
op
The binary operator: Add (+), Subtract(-), Multiply(*), Divide (/).
lhs
the left-hand side of the binary operator op.
rhs
The right-hand side of the operator.
answer
