Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
The list of available operators is controlled by the template file selected when loading a model and result, and it can
be modified by adding or removing <using /> statements in the template.
A result manipulation library that enables user-defined data types to be added to a result, and transitions complex data
manipulation tasks from HyperView to a reusable, modifiable set of libraries that focus solely on result processing tasks.
Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and
minor strain output results of a forming simulation.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
Constant value tables are created from the Constant operator in the Math
library.
When performing operations on value tables using
binary operators, it is sometimes necessary to do so with a constant value. Constant value
tables have the following properties:
All record lookups will return a value, regardless of the ID.
The number of records in a constant value table is 0.
The following snippet demonstrates the usage of a constant value table:
For every record contained in the table in “A”, a scalar quantity of 4.0 will be
returned from the table “econst” with a matching ID. Supporting constant values in this way
allows constant value tables to be interchangeable with “resource” value tables. Constant
value tables are widely used with binary operators, and will fail if passed as both the
lhs and rhs parameters due to the fact that there
are no records.
Important: Constant value tables must always operate with
non-constant value tables in binary operations.
