Error Handling
  • Invalid expression syntax.
  • Valid operators for given datatypes.
  • Multiple subcase/result with non-existing results:
    • Unique aliases for all subcases combined, the expression shows whatever the alias represents.
    • If a particular subcase doesn’t have a datatype, the expression still shows that, however a contour is n/a when applied.
  • Import/export of expressions.
  • Chaining data types.
