SphericalT
Stores the spherical part of src into answer.
src
A tensor value table.
Outputs
answer
  • src and answer must be in tensor format.
  • If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
sph(src)
XML Example
<call name="SphericalT" src="src_tab" answer="ans_tab" />
