PrincipalAxisVector
Stores one of the principal axes of the src tensor into answer.
src
A real tensor value table.
axis
A string "major", "mid", or "minor" (default = "major").
Outputs
answer
  • src and answer must be bound to the same entity type.
  • If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
PrincipalAxisVector(src, "minor")
XML Example
<call name="PrincipalAxisVector" src="src_tab" axis="minor" answer="ans_tab" />
