Binding Change Operators
Binding change operators enable conversion of values from one entity to another related entity.
When performing binding changes, it may be necessary to specify how the values will be aggregated, and depending upon the source value type (scalar, vector, or tensor), only a subset of aggregation modes are valid.
Important: Min, max, and extreme aggregation modes are applicable to real scalar values only.
Aggregation Mode Description Applies to
average Sum of values divided by the number of values. scalar, vector, tensor
sum Total of values. scalar, vector, tensor
min Minimum value. scalar
max Maximum value. scalar
extreme Value with the largest absolute value (with sign). scalar
