BCMatToElem
Converts material values to elemental values.
src
A property value table.
elems
An element entity table.
parts
A part entity table.
props
A property entity table.
mats
A material entity table.
layer_idx
Layer index.
layer_label
Selected layer label.
Outputs
answer
An elemental value table.
  • If src is a vector or tensor table, it should be transformed to the global coordinate system.
  • Aggregation modes are not applicable for this operation.
  • layer_idx = layer index for the chosen data type, assigned by the HyperWorks application, and defaults to the value “@current_slice_index”. @current_slice_index represents the layer index for the chosen datatype.
  • layer_label = layer label for the chosen data type, assigned by the HyperWorks application, and defaults to the value “@current_slice_label”. @current_slice_label represents the layer label for the chosen data type, and is used to determine the layer ID in cases where an index-based layer lookup is invalid.
  • The XML example below does not specify layer_idx or layer_label and uses the defaults.
  • The Expression Builder will provide default values for layer_idx and layer_label.
BCMatToElem(src,elems,parts,props,mats,layer_idx,layer_label)
XML Example
<call name="BCMatToElem" src="mat_val_tab" elems="elem_tab"
parts="part_tab" props="prop_tab"
mats="mat_tab" answer="ans_tab" />
