BCNodeToElem
Aggregates nodal values to elemental values.
src
A nodal value table.
elems
An element entity table.
aggregate
An aggregation mode (avg, sum, min, max, extreme).
Outputs
answer
An elemental value table.
  • If src is a vector or tensor table, it should be transformed to the global coordinate system.
  • min, max, and extreme aggregate modes are valid only for scalar data.
BCNodeToElem(src,elems,aggregate)
XML Example
<call name="BCNodeToElem" src="src_tab" elems="elem_tab"
aggregate="avg" answer="ans_tab" />
