BCPropToElem
Converts property values to elemental values.
src
A property value table.
elems
An element entity table.
parts
A part entity table.
Outputs
answer
An elemental value table.
  • If src is a vector or tensor table, it should be transformed to the global coordinate system.
  • Aggregation modes are not applicable for this operation.
BCPropToElem(src,elems,parts)
XML Example
<call name="BCPropToElem" src="src_tab" elems="elem_tab"
parts="part_tab" answer="ans_tab" />
