HMIN_writemetadata_double()
Transfer metadata of type double to HyperMesh.
void HMIN_writemetadata_double (HM_entitytype entitytype, HM_entityidtype id, char *name, double data);
HyperMesh hminlib Function
entitytype
The type of the entity to which to attach the metadata.
id
The ID of the entity to which to attach the metadata.
name
The name by which the metadata is referenced.
data
The floating point value assigned to the metadata.
None.
