HMIN_transform_nodetoglobal()
Allows nodes to be transformed to a global coordinate system, based on the local coordinate system.
void HMIN_transform_nodetoglobal(double input[3], int type, double origin[3], double axis[3][3], double output[3]);
HyperMesh hminlib Function
input[3]
The coordinates of the node.
type
The type of coordinate system.
origin[3]
The origin of the coordinate system.
axis[3][3]
The axes of the coordinate system.
output[3]
The output of the coordinate system.
None.
