HMIN_surface_writefixedpoint()
Writes a fixed meshing point for a surface.
HMIN_surface_writefixedpoint (double x, double y, double z, int suppressed)
HyperMesh hminlib Function
x, y, z
Location of the fixed point.
suppressed
0 means this is where a vertex or meshing fixed point would not automatically appear, but should be added.
1 means this is where a vertex would have been placed, but should be omitted.
The command, HMIN_writesurfsat() must be called before using HMIN_surface_writefixedpoint() to put fixed mesh points upon a surface.
None.
