HMIN_ply_solver_write()
Writes a ply entity.
void HMIN_ply_solver_write(HM_entityidtype id, char *name, int color, HM_entityidtype material_id, double thickness1, double orientation, unsigned int integration_points, unsigned char result_request, double thickness2, double thickness3, double thickness4, HM_entityidtype table_id, unsigned int table_idpool);
HyperMesh hminlib Function
id
The ID of the ply.
name
The name of the ply.
color
The color of the ply. Valid values are 1-64.
material_id
The ID of the material to assign to the ply. The material must already exist.
thickness
The thickness of the ply.
orientation
The ply orientation angle, in degrees, relative to the element material coordinate system (-360 > orientation <= 360).
integration_points
The number of integration points through the ply thickness. The standard value is 3.
result_request
Flag indicating whether to request output results for the ply (0=no, 1=yes). The default value is 0 and input is not required.
thickness2
Ply thickness 2, valid only for ANSYS. The standard value is 0.
thickness3
Ply thickness 3, valid only for ANSYS. The default value is 0 and input is not required.
thickness4
Ply thickness 4, valid only for ANSYS. The default value is 0 and input is not required.
table_id
The ID of the table containing the drape information, valid only for OptiStruct.
table_idpool
The solver ID pool the table belongs to, valid only for OptiStruct.
None.
Version History
12.0.110
