HMIN_plot_writebounds()
Writes the bounds of the plot to HyperMesh. Allows you to show specific sections of the plot.
void HMIN_plot_writebounds(double xmin, double xmax, double ymin, double ymax);
HyperMesh hminlib Function
xmin
The x value of the lower left axis range.
xmax
The x value of the upper right axis range.
ymin
The y value of the lower left axis range.
ymax
The y value of the upper right axis range.
None.
