HMIN_optiresponse_write()
Writes optiresponses to HyperMesh.
void HMIN_optiresponse_write(HM_entityidtype id,char *name,unsigned int response,unsigned int property,unsigned int region,unsigned int attribute_a,double attribute_b, int attribute1max, unsigned int * attribute1_list, HM_entityidtype functionid,int loadsteplistmax, int * loadsteplist, double * loadstepweightlist, int nmodes, int * modes, double * weights, double norm,int desvarlistmax,unsigned int *desvarlist,int tableentrylistmax,char * tableentrylist,int responselistmax,unsigned int *responselist,int function_loadsteplistmax,unsigned int *function_loadsteplist,int nodelistmax,unsigned int *nodelist,unsigned int *coordinate_type_list,int dvprelmax, unsigned int * dvprellist)
HyperMesh hminlib Function
id
The ID of the response.
name
The name of the response.
response
Type of the response.
property
In case of property response then property is the property type.
region
Region identifier.
attribute a
Attribute of a response.
attribute b
attribute1max
Number of attributes in attribute1_list.
attribute1_list
PID, MID, EID or Grid ID as referenced by property and response.
functionid
Dequation ID for DRESP2 type responses.
loadsteplistmax
Number of loadsteps for WCOMP and COMB responses.
loadsteplist
List of loadstep (subcase) Ids for WCOMP and COMB responses.
nmodes
Number of modes for WCOMP, COMB and WFREQ responses.
modes
Modes for WCOMP, COMB and WFREQ responses.
weights
Weights for WCOMP, COMB and WFREQ responses.
norm
Value of normalization factor that is used for normalizing the contributions of compliances and eigenvalues.
desvarlistmax
Number of design variables in DRESP2 type response.
dexvarlist
List of design variable Ids in DRESP2 type response.
tableentrylistmax
Number of table entries in DRESP2 type response.
tableentrylist
List of table entry Ids in DRESP2 type response.
responselistmax
Number of responses in DRESP2 type response.
responslist
List of response Ids in DRESP2 type response.
Number of load steps in DRESP2 type response if DRESP1L is defined.
List of load step Ids in DRESP2 type response if DRESP1L is defined.
nodelistmax
Number of nodes (GRIDs) in DRESP2 type response.
nodelist
List of nodes (GRIDs) in DRESP2 type response.
List of components in DRESP2 type response.
dvprelmax
Number of DVPRELs in DRESP2 type response.
dvprellist
List of DVPREL Ids in DRESP2 type response.
None.
