HMIN_optidscreen_write()
Writes design constraint screening to HyperMesh.
void HMIN_optidscreen_write(HM_entityidtype id,char *name,double DispThreshold,int DispMaxc,char DispToggle, double StressThreshold,int StressMaxc,char StressToggle, double EquaThreshold,int EquaMaxc,char EquaToggle, double CompThreshold, int CompMaxc,char CompToggle)
HyperMesh hminlib Function
id
The ID of the optidscreen.
name
The name of the optidscreen.
dispthreshold
Displacement threshold value.
dispmaxc
Maximum number of constraints to be retained for displacements.
disptoggle
Toggle variable for displacement type (0: not used, 1: used).
stressthreshold
Stress threshold value.
stressmaxc
Maximum number of constraints to be retained for stresses.
stresstoggle
Toggle variable for stress type (0: not used, 1: used).
equathreshold
Equation threshold value.
equamaxc
Maximum number of constraints to be retained for equations.
equatoggle
Toggle variable for equation type (0: not used, 1: used).
compthreshold
Compliance threshold value.
compmaxc
Maximum number of constraints to be retained for compliances.
comptoggle
Toggle variable for compliance type (0: not used, 1: used).
None.
