HMIN_opticonstraint_write()
Writes optimization constraint to HyperMesh.
void HMIN_opticonstraint_write(HM_entityidtype id,char *name, int bound,double lowerbound,double upperbound, HM_entityidtype responseid, int loadsteplistmax, int * loadsteplist)
HyperMesh hminlib Function
id
The ID of the opticonstraint.
name
The name of the opticonstraint.
bound
Flag to indicate which bound is active (0: lower bound, 1: upper bound, 2: both bounds)
lowerbound
Lower bound on response.
upperbound
Upper bound on response.
responseid
The ID of optimization response in the constraint.
loadsteplistmax
Number of load steps (subcases) for which the constraint is defined.
loadsteplist
List of load step IDs (subcases) for which the constraint is defined.
None.
